RV-10 QB Tunnel Brake Lines
rv6ejguy
A note to those with QB RV10 kits. Mine had the heater tee already riveted into the tunnel sides so there is no nice way to get the brake lines underneath as the plans show. You either run them over top or de-rivet the heater tee and run them underneath. Too bad Van's just didn't cleco the tee in place.
Just drill out the rivets and use pop rivets to put the T back in, like us SB builders.
