pierre smith
I bought some aftermarket stainless steel door lock blocks from a vendor on here and they are beautifully done.
The problem is that the original builder of my -10 must have cut the forward locking pin on the pilot's side too short. It only protrudes from the door 1 3/16", while the passenger door locking pin protrudes 1 1/2". The pilot's side forward locking pin goes into a 1/2" thick nylon block whereas the aftermarket block is about 1/2 that thickness and I'm afraid that the bevel of the front pin will not go all the way through the aftermarket block and could possibly fly open in flight.
Would one of you guys kindly measure the length that the forward pin protrudes fron the door with the latch in the closed position?
Thanks in advance,
Thanks in advance,
