KiloWhiskey1
I'm trying to help a friend sort out a high oil temp problem on his newly flown RV-10. He has flown the phase 1 time and is now running Phillips 20/50. The cowl exit has been trimmed back, which helped the temps some. However, he is still seeing 225 degrees in climb.
What have others done to successfully address this issue?
Cowl flap? Larger or different oil cooler? Cold cooling air directed on the oil cooler?
Any and all help would be much appreciated.
Keith
Keith
