Ivan Kristensen
During regular maintenance I noticed that the flange, holding the 4" scat hose for the oil cooler, was cracking. The cracking had extended 3/4 of the way around and needed immediate attention. This obviously has potential serious consequence should it break off all together.
Now in defense of the original Vans part I had installed an "after market" butterfly valve to control the airflow from the cockpit. This obviously caused additional weight and stresses on this flange from engine vibration and is likely the reason that the weld of the flange cracked.
A better solution to this problem might be to mount the butterfly valve on the Oil cooler, this would isolate it from the engine vibrations.
The pictures below will tell the story and show the fix.
My long time friend and repeat RV offender Roy Pinner helped me with parts and tools for this repair. Thanks Roy! It was on my way back from his place, just before dark over central Florida, I snapped the picture below.
