Eyeballs
Good idea to get as much of these penetrations drilled and ready.
Eyeballs itself I believe can be custom drilled but the pattern for the cut out is the same for all of them. I have four of these installed in the recess (throttle, mixture, governor and purge valve) and several others in locations for wiring, alternate air, etc. Being able to split them and open a large hole to fit cables and wires with connectors attached to them such as BNC connectors and other terminals can greatly simplify your FWF wiring job.
Having a couple more of these installed than you think you need is a good idea as well.
For battery and alternator cables I prefer these bulkhead connectors and you can install these as well
https://www.amazon.com/battery-bulkhead-connector/s?k=battery+bulkhead+connector
Mine came from a marine supply store and look a bit more solid, look around a bit for the best quality.
Lastly, never miss an opportunity to install nut plates.
These are cheap and if you don't need them just fill the hole with a screw.
I put a row of these along to top side of the firewall as well as numerous other places. your heater cables will need one on each side and other hardware I can't think of. In any case, once the cabin top is on and the rudder pedals are installed it will be nearly impossible to buck a rivet on a nut plate behind the firewall.
