With the stock mag set up you need Slick start but it is not included in the package. Also make sure you get the heavy duty starter, not sure what they come with now but I had to swap mine out.
Like Bob said, all kinds of thing you could add. Having said that, here's what I deleted from the FWF kit:
ES ALTERNATOR DELUXE 60A kit
VA-189 FUEL LINE IO-540 (this is the line from the mech fuel pump to the servo)
Because of my setup (AFP fuel injection with purge valve and G3X sensors) I'm adding a -4 fuel line from the purge valve to the firewall, two -6 fuel lines to replace the VA-189 (two because I'm inserting my redcube between the mech fuel pump and the servo) and I'm replacing the VA-119 MP hose as it's way too short for my application (I would have deleted it had I known this at the time).
I'm also replacing the stock breather tube with the Anti-Splat Aero setup.
My bad, I should have explained why I deleted that kit. I needed more juice than 60A, so for the alt kit, I simply bought the PlanePower 70A model instead from ACS. The alternators come with all the required mounting hardware regardless of where you buy them from.
Unless you get the OEM IO-540 engine from Van's. You need the new bushing kit, which at the moment, isn't included in the FWF kit. Van's has been charging folks $35 for it.
It's a long story and in the archives.
bob
Thanks to all again,
I'm assuming that these bushings are for mounting, and spacing the alternator for correct alignment..![]()
