RV-10 Finish Kit Contents
Blizzard
Working on the fuselage at this time and need to get the finish kit on order. I have several questions about the contents. Where can you find a list of the items that are in the finish kit? Building everything pretty much per plans. Anything different is mostly cosmetic to the interior Planning on using Aerosport Products for some of the items like seats, throttle quadrant, panel, overhead panel and side panels, etc. Should I try to leave some items off the order or just order as is and sell what I don't use online? Thanks
Ask Van's for one.
This is what they gave me back in 2016/17 timeframe and it probably hasn't changed much, but you should probably get an updated one to be sure.
I tried to remove what I knew I was going to replace with after market stuff.
Lessens the hassle of trying to sell/ship it. Things like tires/brakes, windows, and cowl if you're going with Showplanes version depending on what your plans are.
  • 10 finish.pdf
