Here is a list of modifications I made/am making to the empennage for your consideration:
Wire bundle and conduit within the VS for possible future installation of a camera and/or antenna in the VS tip fairing.
Removable VS tip fairing (via nutplates in the fairing).
Bonding straps between VS and Rudder, HS and Elevators.
Nutplates for static wicks.
Rudder trim tab w/ servo.
Tail position/strobe light.
Removable lower rudder fairing.
Rudder cable exit fairings on the tail cone.
NACA intakes for overhead console ventilation.
NAV antenna hardpoint (a la Tim Olson's installation).
ELT antenna hardpoint (top center of tail cone).
ELT mount bracket (using the right-side variant of Van's strobe PS mount tray).
Oxygen tank/valve/regulator/fill station/pressure sender.
External power receptacle/contactor/OVM/breaker/indicator.
Elevator autopilot servo.
Custom magnetometer tray.
Conduits for tidy wire routing within tail cone.
Odyssey 925 battery box.
Custom grounding plate with two AN4-sized nutplates and a forest-of-tabs.
Hope that gives you some ideas.
-Mouser
#40988
http://mouser.org/projects/rv-10/
