I have an RV-10 that has been flying for several years with the stock Vans door seals. I really like the finished look that the McMaster Carr door seal adds to the aircraft. I purchased the seal material but installation is not as easy as I though. Everyone that has installed this type of seal says that they had to remove large quantities of material around the cabin door lip to get it to fit correctly. My question for anyone that removed this material either during the building process or after is how did you do it? What type of tools did you use? I know that dust is going to be a problem but I can deal with that by taping off the door area from the inside and doing one side at a time. I just need to know what kind of tool does the best job with the least amount of mess. Any suggestions would be appreciated.
