Hi guys:
A good friend of mine here in the Minneapolis area recently made the first flight of his new RV-10. It is a beautiful machine with a full Chelton EFIS package. I have an interest in the initial testing of this airplane as I will be helping to fly off the 40 hours over the next few weeks.
Sunday during a normal takeoff, my friend had the left door suddently rip off the airplane!! This happened at about 100 ft above the runway. A cool head prevailed and he circled back to land the "open cockpit" RV-10. Believe it or not, the door was laying in the middle of the runway.
After retreiving the door and taxiing in, it turned out the door was amazingly unscathed. One corner had a small amount of damage and a couple scratches on the plexiglas. No other damage to the airframe. The hinges had cleanly broken and the snubber had pulled out the pop rivets which held it in place.
As it turned out, even though the door latch was secure, apparently the rear pin was latched outside the airplane. In other words, since the door is somewhat flexible, one has to be careful that one does not assume the rear pin in extended into the door frame.
So the moral of the story is that it might be a wise idea to built your RV-10 with 4 microswitches and a door latch warning system to be certain that the doors and pins are secure.
