Although I have a two bladed prop, I used the hinge material all the way except for the lower cowl bottom. I like the clean look, and I am not sure how just changing from hinge to quarter turns would help the issue. The issue with the three blade is the blades never get out of the way, making the stock method of fabrication difficult to remove. Several mods can be done, eliminating the lower front ramp baffle. Cutting a much longer slot for the nose gear and fabing a cover plate, some have completely separated the air intake snorkel and using quarter turns to remove it.
I am sure you will get some good responses from those with more specific experience with the 3 bladed prop.
