Aerosport1
After flying my RV-10 for over 300 hrs and numerous night landings I realized the wing tip lights did not light up the center of the runway once on the ground. I also elected not to mount leading edge lights at the time of construction and put some big HID's in. They worked great until about 25 feet above ground. So my solution was to develope a taxi light that will fit in the nose cowl. Attached is a picture of the final product. This light can be installed in any flying RV-10. No painting of the cowl is required. You will just need to paint the light fixture to match your Paint. This will be a new product from Aerosport Products and available soon after testing. There are 2 light options that will fit the fixture. Installation of the light fixture only takes about 2 Hrs once light is painted.
http://aerosportproducts.com
