I checked Aircraft Spruce, and they don't list the same wheel parts breakdowns as we have....we have the 40-59A wheel assembly, and the 30-59E Brake Assembly. Doing a little online searching, I found the parts at one of my favorite suppliers...skygeek.com (seems to describe me, I guess).
Below is a list of all of the replacement parts other than bolts, nuts, and bearings, for ONE side. The quantity of linings and rivets is the total for doing TWO wheels. The confusing part for me was the 153-00300 and 153-00400 Ring-Grease Seals. I had to look at my original RV-10 plans to find out the difference as they BOTH are listed as "Figure No. 9". Doing a little checking finds that the 153-00400 is used on the inner, with the large flat felt. The 153-00300 is used on the outer. I thought I'd pass these parts lists and links on because it is hard to find a good blowup diagram on the net. If the links below are ever broken, send me an email and I saved them as .pdf's.
Qty P/N Desc Note Fig. Price ea
1 153-00300153-00300 Ring-Grease SealOuter - 1 per side Figure No. 9 $6.49
2 153-0040053-00400 Ring-Grease SealInnter - 2 per side Figure No. 9 $6.99
1 153-01500153-01500 Ring-Grease Seal Figure No. 10 $9.75
1 154-00300154-00300 Felt-Grease Seal Figure No. 11 $4.42
1 155-00100154-01300 Felt-Grease Seal Figure No. 12 $4.79
2 066-11200155-00100 Snap Ring Figure No. 13 $5.70
4 066-11200066-11200 Lining Figure No. 11 $18.62
8 105-00200105-00200 Rivet Figure No. 12 $0.35
