Has anyone installed the airflow oil cooler and can provide a comparison with vans supplied oil cooler? I recently flew out of a high altitude airport and had to reduce my VS to to 100/min in order to remain around 220 on my oil temp.
It is possible that my recently Vernatherm replacement has gone bad. I am in the process of checking all the boxes including the possibility of viscosity valve installation..
If you do not have a comparison, can you comment on the oil cooler performance?
Thank you.
Thank you.
