I sent this email to Van's support about a week ago, but got no response. I'm 99% sure this is nothing to be concerned about, but figured I'd just pass along the question to this group and see if someone can give me a warm and fuzzy feeling that all is good. Maybe someone who has not yet installed their aileron bearings might be able to give a little check for me. I'd appreciate it.
Here's the email I sent to Van's:
I had an EAA tech councilor inspect my progress. He noticed that all four aileron bearings have ?lateral play.? If you hold the bearing with a finger on either side, you can ?wiggle? it back and forth (the tech counselor estimates about 20/1000?s of movement). Note the ?play? is in the bearing itself, not between the bearing?s flange and the bracket. In other words, if I take a bearing as provided in the kit, before installed, I think the play exists between the bearing and its flange. I can?t prove this because all the bearings I got in the kit are installed. Can you verify whether or not this ?play? is normal? The (poor) picture below shows the bearing as installed.
http://airplane.athomeinthewilburness.com/wp-content/uploads/2012/01/IMG-20120114-00043.jpg
Thanks for any help,
