RVjim
MT Propeller has designed a 4 blade propeller for the IO-540 engine on the RVseries aircraft.
This propeller and spinner assembly weighs about 54 pounds.
It uses the same basic blade shape as that used on the MT 3 blade propellers for the Lyc. 360 engine on the RV series aircraft.
If you've noticed the discussion in the flight test forum, you can see the significance of a 4 blade propeller and relative aircraft vibration levels.
Jim Ayers
Jim Ayers
