I am rebuilding an O-320 for the RV-6A that I am building. Unfortunately I will not have a hanger and will have to do my work at a tie down once I get to the airport.
I would like to run the 320 in my garage to check for any major problems, leaks, etc. as I will have limited tools and time at the tie down. I do not want to swing the prop in my garage. Is there any problem running the the Lycoming without a prop? Any specific limitations in doing so?
I have not built a stand, but could. Assumed I would run it while hung on the plane.
Thanks for your guidance here.
Larry
Larry
