Wasn?t sure where to put this, hope this is the right spot. I am running wire in my 8A and have a few questions. I am mounting the ADAHRS for the sky view behind the aft baggage compartment and have found a good way thru the center section for the wire up to the display but it means the wirer from the ADAHRS will run right next to the RG 400 for the comm and transponder. Is this ok, the wirers will run together for about 4'? I don?t know if I can add holes to the center section and if I could, I would rather not.
Questions #2 can I run two COMM and one transponder antenna wires all together, as in where they are touching? three Separate runs of RG400 of course.
Thanks matt
Thanks matt
