Hi, I have a few RV questions again.
I’m working on tuning the run up check in an FSX RV7 simulator.
The engine is a 180hp IO360 with a constant speed prop.
I’ve only flown a fixed pitch Cherokee so I’m a bit unfamiliar.
Here’s what I do…
Set prop lever full forward.
Set throttle for 1700 RPM; pitch goes to 15deg (full fine); MP is at ~ 15”Hg (at sea level)
Set Left Mag only; RPM drops by 70
Set Right Mag only; RPM drops by 72
Set prop lever full aft; RPM drops to 1500
Does this sound right? Do you get/use similar values?
I’m especially interested in the lowest rpm your prop governor can get.
The prop "is" a pretend Hartzell (HC-C2YK-1BF) for what it's worth![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Danny
Here’s what I do…
Danny
