I'm in the process of wiring and have a question. I've done some searching and haven't had much luck.
I'm trying to figure out the best method of getting the wires for the strobe and tail light
through the spar on the vertical stab.
It seems the best location would be exactly in the center of the VS Spar, just below the bottom hinge brackets for the rudder.
The problem there is with the "A" models. The hole would have to go through the tie down bracket also, which is pretty thick, though hollow. It seems like it will take at least a 7/16' hole for a bushing to accomodate the wires. Is this the best way or is there a better
one?
All suggestions are appreciated.
one?
