Stockmanreef
The rv-10 requires a rudder trim tab. Any one got an ideas if the rv-14 will require a rudder trim tab? Or is this a wild card at this point?
I will be extremely surprised if it does not.
The internal spring loaded rudder trim is the way to go, no need for an external tab, less drag, and if you really want to fit one later you can.
