Space Cadet
Newbie question-
Getting set to rivet up the rudder, with the electric rudder trim mod in place (like Vic's but straight to airflow like Phil's). Put my servo one rib above the middle hinge point.
Question is, I can't see where to best run the wiring. I assume I should put something in place now prior to riveting it all up, seems easiest. What's the best wire routing? Put a hole in the VS web near the hinge point with a grommet? Seems like the HS will be in the way then. Run it down through the rudder to the bottom of the VS (and therefore the bottom of the fuse where the lines will probably be), then across the gap? Does it need to be near the hinge points?
I've already riveted up the VS, so that makes it a bit tougher to get access. Can't see any wiring on the pictures posted by various folks I could find...
Thx,
Dwight
Thx,
Dwight
