RE: Rudder trim
I have just returned from a 32.5 hour x-country trip and as soon as I returned, I ordered the ML Skunkworks rudder trim. I have a 16 month old 9A with 230 TT. The system works on the same principle as the aileron trim, biased springs. The good part is that it is installed under the instrument panel with the two arms clamped to the rudder bars. A very clean install. I would encourage you to check it out before cutting the rudder and engineering then installing the associated monkey motion. Dan.
