When trimming the trailing edge flush with the rudder skin at the top side of the rudder, I had to remove a bit extra to remove all of the lighting hole at the top. This resulted in the wedge being slightly shorter than the top of the skin:
https://eaabuilderslog.org/?blprojentry&proj=7gbEJNhMU&e=7ikb0QcQ0&listcat=&sid=
Is this acceptable?
Also, the trailing edge corners on the skin were left sharp by Vans. Do I want to break/slightly round these edges?
Thanks!
Is this acceptable?
Thanks!
