The aft three 3/32 holes in the upper edge of R-901-L and R-901-R should be drilled to #30 and dimpled. These holes will later be used to attach the R-909 rudder tip. While the holes could be opened up to #30 when drilling the tip to the rudder, it would be nearly impossible to dimple the skins because the rudder is so narrow at that location.
These?
These?
