In Section 5.8, reference is made to a "flat faced narrow diameter rivet set".
The closest thing I have is a back rivet set but this can't be used because of the spring sleeve. I DO have a C-Frame dimpler, but the ram is deformed from use and won't fit in the rivet gun anymore.
Back about 10+ years ago, I used a mushroom set, but wasn't completely successful avoiding a "smile" or two.
From builder sites, it appears that most people are using mushroom sets, but I'd like to use the type of set Van's recommends.
If you've used a "flat faced narrow diameter rivet set", please let me know your source for it.
Thank you.
Thank you.
