Ready to dimple the stiffeners.....
Seems like when I start to squeeze the dimpler, the dies would distort the radius of the stiffener bend?
Explained another way -- the diameter of the dimple die is too big to fit flat on the stiffener, it looks like the die will "hit" the bend in the stiffener and distort the bend radius wherever I dimple??
The holes were pre-drilled, so *I* didn't drill to close to the 90 degree bend in the stiffeners... I'm pretty sure Vans didn't either... so is there a smaller diameter dimple die?
Or am I sweating the small stuff?
