Bill.Peyton
Ok, here is what I am trying to do. I would like to have springs attached to the rudder cable ends to help in protecting the rudder from wind and to also eventually develop a rudder trim system similar to the piper aircraft. I test installed two rudder return springs which attached at the base of the Pilot Right peddle and the Co-Pilot Left peddle. The spring is attached at the other end to a bracket on the side of the tunnel next to the firewall. The issue is, now there is tension on the cables at all times, it is amazing how much friction the cables have as they thread there way from the front to the rear of the aircraft. The lack of pulleys really shows. My concern is the rudder cables will eventually wear right through the snap bushings. I am now looking at strategically installing pulleys in three different locations to get rid of a lot of the binding a wear issues.
For those of you flying, have you ever inspected the snap bushings for wear?
Has anyone else tried a return spring arrangement?
