Rudder Spar Assembly Hinge Clearances
Hi All,
I am trial fitting the rudder spar to the vertical stab and the directions call for using AN960-10 and/or 10L washers to set the appropriate clearance but do not specify what that is. Should it fit with no vertical play at all? :confused: Any suggestions?
Also, in setting the clearances should I tighten the bolt/nut to the appropriate torque setting?
Thanks.
Dave Jablon
RV 12 - Empennage Kit Started
More or less - yes
You don't want it to move up and down. The bearing does the turning, so you can have it tight. The washers are just shims.
John Bender
