tmcguff
Member
I recently finished the rudder on my plane and wanted to share an idea for dealing with the last few rivets on the top and bottom ribs.
[/IMG]
Basically it involves using a regular screwdriver and or chisel. It turns out that most screwdrivers (in my case a craftsman) have about the same slope on the blade as the slope on the rudder ribs. First put both rivets in place and put the rivets over a backplate. Next take a screwdriver with a blade that will fit comfortably between the two rivets. The farther you push the screwdriver blade between the rivets the more they want to separate. Only put enough pressure to snug the blade between the shop side of the rivets without pushing the manufactured side out of the hole. Center the handle between the upper and lower part of the rib. This is to ensure the same angle for both rivets. This is easy to do with your free hand or with a support. Use a mushroom head rivet set and give it a short hit. The tendency is for the screwdriver to be pushed away from the rivets but can easily be held in place with your free hand. Simply move the screwdriver farther between the rivets as you set the rivets until you get the desired result. If you find that one rivet compresses more than the other you can turn the rudder over and use the rivet gun on the other rivet. When I did this they seemed to compress at about the same rate.
![dscn6286tk0.jpg](/proxy.php?image=http%3A%2F%2Fimg87.imageshack.us%2Fimg87%2F3081%2Fdscn6286tk0.jpg&hash=88c5480cfe8014fe9b35d636f94eb53a)
