Can rudder return springs be added to already built flying RV6A
6 67MK Larry Active Member Jul 15, 2009 #1 Can rudder return springs be added to already built flying RV6A
flion Well Known Member Jul 15, 2009 #2 Yes. Ok, I'll elaborate a bit. You'll have to do a little panel-crawling. I ran my springs to the vertical angle on the firewall on either side; you'll need to get in there and drill a hole to accept the spring. Not an easy task but do-able.
