My (I didn't build it), RV 7A has Aero Flash wing tip strobes mounted recessed in the wing tip fairing, under plexi-glass and so aren't visable from directly behind the airplane. My rudder has only the Aero Flash white position light (PN 153-0011). I would like to replace the rudder position light with the Aero Flash combination Position/ Strobe unit (PN 153-0011-12) to make it legal for night flight ( I have no tail anti-collision light). They fit in the same hole. My question is: The position light weighs 2.5 ounces and the Combination Pos. light/ Strobe weighs 3.5 ounces, Will I need to remove and re-balance the rudder? Or is the rudder typically balance in the 7?
Bernie
Bernie
