RV-8 with ground adjustable pedals. Rear seat pedals deflect the rudder to the stops - no problem. Front seat pedals do not. However, if I disconnect the brake cylinder from the pedal I get full deflection to the stops. So, I surmise a problem with the cylinders and/or the way I've installed them. Sent pics to Vans - no help. Hopefully one of you will see the error.
Deflection should be 2" from elevator - more like 4" with brake cylinders attached.
Help!
![rrm9hz.jpg](/proxy.php?image=http%3A%2F%2Fi62.tinypic.com%2Frrm9hz.jpg&hash=bfbd5cfb10effbfebe2c9241880eeb2f)
![344w5cg.jpg](/proxy.php?image=http%3A%2F%2Fi57.tinypic.com%2F344w5cg.jpg&hash=57a698395ef6a9fb6e13f99d979d5cae)
![2ai3qio.jpg](/proxy.php?image=http%3A%2F%2Fi60.tinypic.com%2F2ai3qio.jpg&hash=3c4671634b3da91aa8067989c1b4b21b)
![311mgzm.jpg](/proxy.php?image=http%3A%2F%2Fi62.tinypic.com%2F311mgzm.jpg&hash=2cfae5c77356d524b53d22350d65794d)
![2ui96yr.jpg](/proxy.php?image=http%3A%2F%2Fi58.tinypic.com%2F2ui96yr.jpg&hash=4b156783cbf31d795de7b8794f704fb0)
Help!
