rudder pedal adjust holes
g zero
the plans call for one inch spacing in the the holes you drill in the ajustable pedel slide tube. Did you use this dimension , would you change it ????
Pedal adjustment
Same answer, mine has never moved from the full forward position.
John Clark
RV8 N18U "Sunshine"
KSBA
I used the one inch per plans spacing...seems ideal. Unlike the experience of others that have commented, I prefer to normally use the aft most hole position. With the rudder pedals locked in the most forward hole close to the firewall, I can barely reach em....perfect for stretching out my legs. With a pull of the lanyard, cockpit adjustable rudder pedals are a great option to have even if the pedals are mostly locked into a single position most of the time.
