jsharkey
How have others routed the tail light and strobe wires to the end of the lower rudder fairing?
In particular how high on the rudder/rear fuselage bulkhead did you pass the cables? If it's low enough to be in line with the fairing then it has to go through the tail spring steel bracket. Higher up and it could pass down through the D-nose of the rudder and under the rudder horn bracket into the fairing.
Also how did you account for the swing or motion of the rudder on the cables? Where did you route the "slack"? Or did you cut a horizontal slot in the nose of the rudder to allow it to move over a more or less fixed cable?
And - where did you break the cables? At the lights or somewhere near the hinge line?
Any pictures would be much appreciated.
Jim Sharkey
RV6 Tip-up O360-A1A FP
Getting ready to take to the airport!
Jim Sharkey
