![](/proxy.php?image=http%3A%2F%2Fwww.repucci.com%2Fbill%2Ffuselage%2Ftail%2520wheel%2520spring%2520attachment_small.jpg&hash=4f8dc19fafb7ef7f48cefefb7ff7ea79)
... The other thing to notice is the Eye-bolts used to attach the steering spring. A similar arrangement is put on the bottom of the rudder horn. The advantage here is the spring is almost horizontal and should be out of the way of the rudder bottom. In addition, when the spring starts wearing away at the attachment points, the Eye-bolts are easy to replace. This was not my idea, it was in one of the OLD RVaitors, which are good reading. (Parts List, four of each are required: Eye Bold Drilled AN42B-5, Cable Shackles AN115-21, Bolt AN3-6 (Drilled shank), Washer AN960-10, Castle nut AN310-3, Cotter pins as needed)
The wheel bolt is long and bushed out on purpose so a Cessna tow bar may be used on the tail wheel. (The white bag is 20 lbs of OO buck shot. It is helping hold the tail down with the engine mounted and no tail or wings installed.) (5/27/07)
