working on installing the rudder cables and find that the spade end of the cable does not fit thru the bushings on the bulkheads.
Doeas anyone have a suggestion on how to solve this problem ??
You'll need to remove the bushings from the bulkheads to get the cable through, then reinstall. With the bushings removed, they'll deform just enough to get the cable through.
Once they're out of the hole you'll be able to squeeze them into an oval shape and the spade will fit through. Then you can click them back into position.
Thanks for all the good advice. Removed the bushings
( only destroyed one in the process) and fed the cables thru
as described. SIMPLE !! Should have been able to figure that one out
myself ........ DUH !!
