If you are working on the tail section, you get 4 rudder cable guides, the small skinny ones, page 10-21, F-01497B. Sometimes when you separate parts, you end up with a couple extra parts that you are not going to use. This is not the case here, you will use the other two guides up front. They send you the bigger set with the fuselage, but you need to use those from the tail kit. They are really small and will get lost, put them somewhere where you can find them when the time comes to install in the front and you won't spend hours looking for them, then give up and have to order them from Van's.![Mad :mad: :mad:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
