I'm not sure if I'm just blind and don't see any callouts in the instructions, or if it's just not in there: I've got the brake pedals mounted to the rudder pedals, and now I need to drill holes for the brake cylinders. Given that the rudder tubes are offset from each other, is there a time tested method for getting the brake pedals set at a good angle and even with each other? I assume they should be set back a bit from the rudder tubes, but not sure how much.
