How much clearance is needed between the fiberglass rudder bottom and the tail spring on a taildragger?
I thought I saw a required amount stated in the plans, but I can't find that dimension now.
I fitted the fiberglass bottom on today and have about 1/4 inch clearance at the most forward, closest point and that distance increases rapidly as it goes aft.
Is that enough, or do I need to raise it just a little more?
