CharlieWaffles
Ok, reached my first point where I need some points I can't find elsewhere. I am finishing the prep for the rudder assembly (7-6) and on step 12: Countersinking the trailing edge (R-1006). I've dimpled the skins (Step 11) with the 3/32 dimplier as usual. I'm using the micro-stop countersinker and have a good handle on its operation. However, when I attempt to create a countersink in R-1006 large enough to hold the skin dimple, I get one of two effects.
1) The countersink is too shallow and a test fit of the skin shows the skin dimple not completely resting in the dimple
2) If I counter sink large enough to fit the skin dimple, the rivet hole in the R1006 is enlarge as the countersinking bit enlarges the hole by intersecting the countersink on the opposite side.
What am I doing wrong? Is the enlarge hole normal? Should I just use a 1/8 countersink instead so I dont get the chatter from the countersink schooting around in the hole as it enlarges?
