Jack-
Because the VS is offset, when the rudder is in neutral position, one side of the rudder horn is a bit forward of the other side.
Yep, mine is offset along with the pedal upper tubes. I have not paid any attention to it as I use whatever it takes to line up with the center line. I may fix it too.
I put an arrow on my pitch trim indicator for solo takeoff(4th LED from bottom) and another at gross takeoff(one LED lower, towards nose down).
Yes, the pedals are offset the distance between the pedal tubes. Never thought anything about it either. If we "fix" it, will that mean slightly less rudder throw in one direction? As I think about this, I can't remember ever checking to see if the rudder is against the stop when the pedals are pushed full forward on either side. Is the rudder stop what physically limits rudder pedal throw? I will have to check that out! Inquiring minds want to know.
