Yesterday we have done the first engine run and most things seems to be OK.
standard setup on a Lycoming IO-540 connected to an EMS D120.
We have seen 2750 RPM max (static) and I thought it should be about 2700. Did not have time to check everything, but the did check the Dynon setup - it is at 1.5 pulses. Then the travel on the CSU unit is also from stop to stop. Any ideas?
We also have the red cube fuel flow sender unit. The Dynon is set at 33000 (if I remember correctly) and I see in the documentation that for the red cube it might have to be 68000. Again - any thoughts on this one would be welcomed.
