NorthernRV4
I've been researching and planning the routing of Pitot/AoA lines and many builders of -7/8's have run the lines through the main ribs close to the spar web. There's quite a difference in the aileron bellcrank and the -7/8 lack the reinforcing angles of the -4. My main question is whether running the lines aft of main spar creates some challenges in routing into the fuselage that doesn't exist with the 7/8 aircraft builders. I have a pre-view plan set for an -8 and the center section certainly doesn't have extra holes for running lines that I can see. I assume in either case you'd have to run lines above the main spar in the fuselage sidewall to get to the instrument panel.
I have already installed the SafeAir1 pitot mast just outboard of the stock location and plan to use the Dynon unheated Pitot/AoA. After careful consideration taking into account Van's recommended wire routing (here: http://www.vansaircraft.com/pdf/Wing_Wiring.pdf) I think the following layout works best. The Pitot/AoA lines would be routed at the top of the rib through snap bushing and the wiring would be routed at the bottom in the Van's corrugated conduit via a 3/4" hole. Looking for community feedback before making this permanent.
[/url]Pitot/AoA & Conduit routing by James Soutar, on Flickr[/IMG]
![35569476804_0f7167d96f_c.jpg](/proxy.php?image=http%3A%2F%2F%5Burl%3Dhttps%3A%2F%2Fflic.kr%2Fp%2FWc9Ses%5D%5Bimg%5Dhttps%3A%2F%2Ffarm5.staticflickr.com%2F4394%2F35569476804_0f7167d96f_c.jpg&hash=650010b1e1cdbad11eb9809c37d0c9d9)
![36404610075_ff7316db28_c.jpg](/proxy.php?image=http%3A%2F%2F%5Burl%3Dhttps%3A%2F%2Fflic.kr%2Fp%2FXsX9fX%5D%5Bimg%5Dhttps%3A%2F%2Ffarm5.staticflickr.com%2F4385%2F36404610075_ff7316db28_c.jpg&hash=5f561e3d593599a5aebb0dd72673ead8)
