Has anyone here used (or considered using) a Rotax 912 to power their RV-9? It's a neat, compact package, and I have access to a couple of ULSs with CS props.
I have quite a bit of time in a Katana, similar in >SOME< respects with an RV-9, and the Diamond moves along quite smartly while just sipping mogas.
Calculations between the Rotax (95hp cont.) and an O-235 (118hp) predict only a modest performance hit.
The 912S/ULS with a CS prop is a good combo. Allows you to get max continuous power (5500 RPM) easily and if you really like the snowmobile noise, you can try and get the full 5800 RPM (5-min takeoff power rating).
Pull the prop back to 5000 RPM and it's nice and quiet and still makes 90+ Hp with lower fuel flows. With a fixed pitch prop set for 4900 RPM static, we find that hot/high takeoff and climb performance suffers, although with the CT, those are relative terms.
If you keep the airplane light, it ought to do Ok, but if you plan a lot of 1800lb takeoffs, the 912S might not be the right engine. Also, I assume that since you're posting here, you don't mind doing your own maintenance. My suggestion is to either find an A&P or Rotax operator that will go over maintenance tasks with you (particularly balancing the carbs and gearbox checks) or go to a 1 or 2 day Rotax school.
The O/IO-240 has the big advantage that any A&P knows how to work on it. Not the case with the Rotax, where we wind up working along side our local A&P when we need work done (S-LSA do not allow the owner to do all inspection / maintenance tasks). Field repairs when something major goes wrong is harder, although you can find parts in some unlikely places (for example, voltage regulator - sometimes a maintenance issue on the Rotax - is stocked by Ducati motorcycle dealers and it's cheaper than the Rotax part to boot. Perhaps that's because it's made by Ducati and rebranded by Rotax....).
As for economy, the 912 likes mogas all right, but if you run at higher RPM / MP, you'll find that the fuel flows aren't that different from a O-240. Also, you can't run the Rotax LOP, since the mixture is set and the carbs are altitude compensating. No idea about how the IO-240 likes LOP.
For a good performance comparison between these two. you can always look at Diamond's POH data for the DA20-100, which uses the 100Hp 912S and a CS prop, and the DA20-C1 , which uses the IO-240 and a FP Sensenich wood prop. Weights and flight surfaces are, IIRC, nearly identical.
TODR
