they say width of the flat part of the "stick" is half a liter. have you noticed yet how many more times you have to turn the prop to burp it when its cold...my highest yet is 73.
Duh...now you tell me John. Too funny. Thats one of those "why didn't I think of that!"
If it is winter in this part of the world, by the time you get the plane back inside the hanger, it is cool enough to turn over. Have done it for years. Have not heard of such a situation, but maybe.
John Bender
I have found that it takes fewer turns if you stop at TDC on each compression stroke and just let the cyl pressure fully bleed down past the rings.
When the oil is real cold it still take quite a few cylinders but it is at least fewer than if you flip it fast.
Is there any detriment to having all the oil in the oil tank while the aircraft/engine is sitting there for an extended (more than a day) time?
I thought that the oil provided some corrosion prevention between runs. If you burp the engine soon after running, it seems to me there would be little in the engine itself.
Like I said, I am probably over thinking the issue.
Joe Hutchison
P.S. Flew with Mitch Lock while home on R&R and he is a true ambassador to RVs and the RV-12. I was pretty sure I wanted RV-12, but he removed any doubts. Thanks Mitch.
There is some good history on the acceptable oil level and burping in some of the "Power ON" columns that Phil Lockwood wrote for EAA.
TODR
It looks like EAA has removed the Sport Pilot magazine articles from their website. You can still get at the articles by googling them. Here is one of the articles that talks about the old and new dipstick.Anyone have the link to these articles??
