BobCollins(AA)
I am looking for rotating beacon to install at the top of VS on my 7A. I looked at the beacon from Aeroled but it looks to big to install on the VS.
Any suggestions?
Any suggestions?
I found this website for led beacon. Has anyone use this product
http://www.kestrobes.com/beacon.htm
Bob, I installed that beacon on the top of my fuselage. The airplane was just about finished and I did not want to tear up the top of the vertical stab or deal with a challenging wire run at that point, so that is why I put it where I did. I think the top of the VS would be the best location. I am very happy with it and have had no problems. Airplane is almost five years old with nearly 700 hours.
David,
Thanks for the info. Do you have picture of your install?
Is a red beacon required?
It might not be required but how does one indicate that the engine is about to come alive? .
What Paul said and turn on your stobes. After the engine is running you can always turn them off until you roll on to the runway.It might not be required but how does one indicate that the engine is about to come alive? Using strobe lights might be a overkill during the day and have a blinding effect at night.
