Rotate speed? Dont ask.
kentb Well Known Member Jun 17, 2011 #2 That ducted fan on the bottom. You should be able to to vertical takeoff and landings. Kent
Mike S Senior Curmudgeon Jun 17, 2011 #4 Looks like the ducted fan on the bottom is a bit shy on inlet area.
ccsmith51 Well Known Member Jun 17, 2011 #5 Seeing the cruiser in the background, it looks like someone has already reported this to the authorities!!
gbrasch Well Known Member Jun 17, 2011 #6 Now that's funny, I don't care who you are. And what department car in the background? I am Tucson PD, RET.
Mel Legacy Member Mentor Jun 17, 2011 #7 Mike S said: Looks like the ducted fan on the bottom is a bit shy on inlet area. Click to expand... And if you check, I think you'll find the pitch is probably wrong.
D don.olandese Well Known Member Jun 17, 2011 #8 first one i've ever seen that... truly WAS made for grass strips.
Jerry Cochran Well Known Member Jun 17, 2011 #9 BD Vanhooz... Where in the world did you find those BD-5 wings? I have the exact same tractor so I could use a set... Great first post, BTW...
pazmanyflyer Well Known Member Jun 17, 2011 #10 I'm guessing higher than other of this type because of the parasitic drag. Might take some scotch-brites to those and see if that helps out.
Capflyer Well Known Member Jun 17, 2011 #12 I'll bet if you clean up the drag from all those clecos you'll pick up a kt or two
mike newall Well Known Member Sponsor Jun 17, 2011 #14 Probably have a similar performance to this.............. http://tinypic.com/player.php?v=2u7vqf8&s=7 PM for details
Mike S Senior Curmudgeon Jun 17, 2011 #15 Technology moves forward In the old days, we had to push our lawnmowers, now they got riding ones. http://www.youtube.com/watch?v=26PpA1kFIWw
S snowbird Active Member Jun 17, 2011 #16 Been done.... http://www.airplanezone.com/NewsgroupPix/DA-11.pdf
