Draker
![IMG_0049-M.jpg](/proxy.php?image=https%3A%2F%2Fphotos.smugmug.com%2FRV7%2FWings%2Fi-23wvzJP%2F0%2F446ff4f6%2FM%2FIMG_0049-M.jpg&hash=575333950d6fdc6f2710c1e607820850)
Weighing my options:
1. Re-order T-703 end rib, T-407 stiffener ring, and 12 nut plates, and re-do the whole part. Concerns: The tank skin is already drilled and dimpled. How will I match-drill to the skin correctly?
2. Rivet a .025 plate over the hole and pro-seal it real good? Concerned this is a high-probability source of leaks.
3. Plug it with some kind of bulkhead fitting?
4. Use the hole as-is. Make two bends in the 3/8" fuel return line so that it can continue to the end bay. This is almost certainly not viable: The line will interfere with the flop tube's operation.
Any other suggestions? I'll give Van's a call tomorrow and see what they have to say. Boy do I feel like an idiot right about now.
