This weekend we got the rollover bar installed and after a long and brutal battle, we want to offer a hint.
The aft bolts are tough! You have the C-668 shim to add, and the aft bolts are under the lip of the side rails. SO, we super glued the shim, washer and nut together, then used a tongue depressor and a piece of double sided foam tape to hold it all together.
We slipped the assembly in place with the depressor, and dropped the bolt in place and turned until it came off the foam tape.
BE CAREFUL NOT TO GET GLUE ON THE THREADS!
CC
CC
